Brake Controller
Old 03-24-2007, 08:43 AM
Stealth06Ram's Avatar
Brake Controller
I know that this topic has been discussed.....
But, What is the Leading Trailer Brake Controller, and can you post pictures of where it you located it in your Truck.
Istallation, Hard, Easy, Get a Mech!!!!
Don't blow up the TIPM!
Other Factors that might apply.
Bumper Pull
Weight of Trailer, Unknown, (If that matters)
Thanks,
Stealth
Old 03-24-2007, 09:05 AM
belgianmagic's Avatar
Mine is right on the dash driver side against the pillar...I popped the cover(for the speakers) fed the wires into the dash and plugged it right into the socket by the e-brake...VELCRO if you need a pic I guess I could get one
Old 03-24-2007, 09:16 AM
John Bellmyer's Avatar
I had a REESE in my 02 CTD. It worked good but when I bought the 05 CTD I upgraded to the PRODIGY. I am very happy with this unit. It's a set it and forget it unit. I mounted it on the dash bottom, right side. Didn't want it in the way of my clutch leg. Wiring is simple. Just match the wire colors on the controller to the wires on the plug that should have come with your truck and plug it into the receptical on the fuse block and you are done.
Old 03-24-2007, 09:29 AM
rock crawler's Avatar
PRODIGY PROPORTIONAL BRAKE!!!! GET THE VEHICLE SPECIFIC HARNESS AND IT'S A 5 MIN. INSTALL!!!
Old 03-24-2007, 09:33 AM
cadent47's Avatar
Can you please post a photo?
Old 03-24-2007, 09:42 AM
Spooler's Avatar
The best brake controller sure isn't a prodigy. It is a BRAKESMART, period. I installed mine on the right/lower side of the steering colmn. 2 screws. Plug and play on the rest. Sensor install wasn't bad either. Sorry no pics.
Old 03-24-2007, 12:15 PM
pic 1...on the dash (velcro)
pic 2 wires fed thru speaker panel (pops right out)
pic 3...wires coming down from top
pic4 plug in right next to the e-brake
GOOD DAY
Old 03-24-2007, 12:43 PM
cadent47's Avatar
GOOD DAY
Thanks! I appreciate it.
Old 03-24-2007, 12:45 PM
rustyshakelford's Avatar
heres a thread i posted a pic of mine in. i think its perfect in an 06 becuase i dont like anything that could go into my legs if i were in an accident and its easily adjusted if need be
https://www.dieseltruckresource.com/...ighlight=brett
brett
Old 03-24-2007, 01:12 PM
i JUST PUT A RED #9 Kasey Kahne hat on top facing front ...hand controls facing out the back ...to keep the hot sun off the brake box
Old 03-24-2007, 03:48 PM
Thanks for all the Replies.
I have the Controller Harnes for the Truck.
I have an Older Never Installed Voyager XP Brake Controller (Tekonsha).
Has anyone used this specific type of controller? Any Issues?
Thanks
Stealth
Old 03-24-2007, 04:35 PM
i have. if i were you, id shop around and get the new prodigy if your going to be towing frequently. i felt like i was always having to adjust the voyager and never really had it dialed in where i wanted it. you can pick a prodigy up fairly reasonable off places like ebay.
brett
Old 03-24-2007, 05:03 PM
Thanks
Stealth
thats what I have no problems...and very easy to adjust
Old 03-24-2007, 05:56 PM
morkable's Avatar
How much better is the brakesmart than the prodigy? Is it worth the extra money?
Thanks
kevin
Old 03-24-2007, 06:22 PM
overcomer401965's Avatar
Quick Reply: Brake Controller
