AUX Stereo Input
Old 01-12-2004, 08:30 AM
kayjh's Avatar
Originally posted by commando
What does the CD input "jack" look like? I pulled out my radio (RBK single CD player with Changer control buttons and "Mode/Eject" button). On the back side there is a large rectangular plug that has power, speaker wires, etc. Next to that is an unoccupied smaller rectangular port. I didn't count the pins. Is that the right input?
I'm trying to hook up a Delphi SkiFi. No cassette player and the FM modulator doesn't fit our antenna jack.
Commando, Can you post a picture of the front and rear of the radio you pulled? We can email the pictures to a few of the electronics outfits that provide the converters and get to the bottom of whether the 2003/04 in dash 6 disc unit can have an electronic "aux" converter added. Thanks
Old 01-12-2004, 10:48 AM
Mike67RS's Avatar
I wish I had taken photos. The CD Changer control jack is a small square 10-pin connector about ½" X ½". On my radio it was just above the main connector. FYI, you can pick up an antenna adapter at most local electronic stores, but the sound quality of an FM modulator does not compare to the direct connect...Mike
Old 01-13-2004, 07:18 AM
kayjh's Avatar
I re-assembled everything already. I ordered a PIE adapter last night. It should be here in a couple of days. I'll let you know if it works.
By the way, mine is a 1 disc CD player.
Ahhh!The 1 disc unit will work because it has an input for the external CD changer. The 6 disc "in dash" changer won't because it doesn't have the external CD input on the back of the unit.
Old 01-13-2004, 08:05 AM
DF5152's Avatar
did u tpull the radio out to check?
Old 01-13-2004, 12:05 PM
Mike67RS's Avatar
This RBQ head unit on E-Bay has the same CD changer port I used on my head unit (RAZ).
http://cgi.ebay.com/ws/eBayISAPI.dll...category=48612
You can see it next to the main connector...a small square 10-pin port. But, the P.I.E. website says the RBQ is not compatible with the interface I have. I am confused now. If you have not already, call or e-mail P.I.E. for clarification. There, I will be quiet now. I hope you work it out, Mike
Old 01-13-2004, 12:09 PM
kayjh's Avatar
No I haven't. I plan to check with the dealer on the radio order code for my truck. That way I'll know what I have and can check with P.I.E. Electronics to see if they have something for my unit. I'm a bit too busy to start pulling the dash apart. Is there a simple way to pull the radio??
Old 06-19-2005, 02:15 PM
1tuffdiesel's Avatar
Kayjh, did you ever find out if your unit was compatible with a PIE interface? I have the same unit as you (RBQ).
Karl
Old 11-13-2005, 09:13 PM
DF5152's Avatar
any updates????
Old 11-15-2005, 03:48 PM
tjr76's Avatar
How about with an RB1 and Uconnect
Does anyone have this combo with a wired adapter for their Ipod?
Old 11-15-2005, 05:04 PM
I jumped through every hoop to see if there was an option for the 6 disc changer and an in line device and the problem is that there are no CD changer controls on the 6 disc unit becuase it doesn't need them. All of the aftermarket iPod type devices use the CD changer controls to communicate between the two devices. Therefore, if you want to get an in line adapter you need a different head unit like the RB1 or RBK, etc.
I've been wanting a more stock setup for navigation with iPod compatability so I decided to get a new RB1 on ebay with the Pie Interface and it sounds amazing.
tjr76, the RB1 with Uconnect won't work with an adapter becuase the Uconnect system uses the small sqaure 10 pin port that the iPod adapters use so it's either one or the other, unfortunately.
Karl
willy sutton
03-15-2012 09:44 AM
mjozefow
06-22-2009 10:37 PM
Flashman
02-04-2008 12:24 PM
Dane Bramage
03-01-2007 01:09 PM
infidel
06-11-2004 08:35 PM
Quick Reply: AUX Stereo Input
