Anyone have a truck with out a cig lighter
I'm thinking of putting my electric seat warmer switch's in that spot, and the one just like it on the passenger side. However, the cig lighter side is not flat, it has a resess to it,,,I think. I called my dealer and he said he couldn't find a lighter delete plate. I just want to see if such a thing existist's. So, is there anyone that does not have a lighter. Thank's
Originally Posted by nickleinonen
my pyro is mounted where the cigg lighter use to be...
I originally thought about putting a gauge in that spot on the passenger side, but there wasn'ts enough room. How in the world did you mount your's. Got pic of it.
pictures all in this gallery. it will fit there, but you need to trim away the inner dash section to make room. i made a template and traced the hole for the gauge around the cigg lighter, then used a dremil with a diamond burr and freehand cut out the hole.. works well, but it is a little hard to read, so it will later get relocated when more gauges get installed [planned are lube oil pressure [mechanical], air pressure, fuel pressure, oil temp, water or trans temp] and egt will go on the pillar, air press on the cigg hole, lube oil, boost and fuel pressures in the cubby, oil temp and water/trans temp on the steering collum...
jon05ctd
09-05-2006 04:56 PM
Bad Ramer Jamer
01-01-2006 03:43 PM
03CTDCO
02-28-2005 06:35 PM
Maccandy
07-13-2004 12:10 PM
