any way to balance tires without stupid weights
#31
dirty goat beads work great have had mine in for 3 or 4 months and love them it is the way to go in my opinion i had a 10000 pack and a 6500 pack and have about 1/4 of the 6500 pack left divided them all as evenly as possible stuck a screwdriver between the rim and tire and dumped them in i made sure the tire was beaded beforehand then broke 1 bead and dumped them in.
#32
anybody have experience with these centramatics i'm almost considering this, although not much info on them.
just had new tires installed at discount, and in case nobody noticed the people that work there are IDIOTS, that treat you like crap, and do the job wrong so you have to go back to here try that and see othrewise come back and will fix it. 200 is worth keeping IDIOTS out of my life
#33
I use balancing beads in my bike and have used them in the last 2 sets of tires prior to these with great results.
This set I bought a large container of air soft pellets and used a scale to figure out how many equated to the amount of weight I needed for each wheel. Been working fantastic for the last year and about 10K miles.... plus they are large enough to not block the valve stem when adding or subtracting air and they ought not clump!
I used an approximate amount based off the weight recommendations for my tire size on innovative balancings' website...
#34
Has anyone had any trouble with the centramatics not fitting over the brakes on their truck? I'm still running stock rims and threw some weights last night and it feels like I'm running down the rumble strip on interstate at 55. I'm considering centramatics as it seems like the long run option for me in terms of price.
#35
The only issue I've seen was that the stud holes on the front set were off just a pinch. You have to carefully bump them on and off with your hand. Other than that, zero problems and no complaints. I've never had tires wear so evenly.
#36
On my Jeep Grand Cherokee I have 37" Super Swamper IROKs and I use just regular old metal BBs for balancing. Works well, been doing it for about 5 years now. The BBs are heavy enough to fall to the bottom and not interfere with airing up and down, which I do every time I go out. Light enough to be where they need to be by 30mph. So far no rusting or damage to the rim, paint is still intact. When I change the tire or pull it off for repair I just collect them with a magnet and then reuse them.
2 boxes of BBs and a small food weigh scale cost me less than $20 at Walmart.
ptextreme
08-12-2008 10:32 AM
wreedCTD
05-09-2007 05:29 PM
sakisaki400
23
12-31-2006 10:17 PM
wallypedal
01-30-2006 05:46 PM
West Coast
01-25-2006 07:03 PM
