Any tips on removing dash for gauge mounting
It looks like the center dash can be removed by pulling foward and allowing the
snap tabs to disengage. Anyone have directions from a service manual for clear
help and possible pictures. I'm getting ready to install my gauges and cubby mount.
Would really appreciate some helpful hints from those who have done this already.
I'm concerned I'll break the dash removing it.
Thanks
Thanks
Top's Younger Twin
Theres a screw down at that 'hook' thingy at the bottom right.
Now I cannot remember it thats the only one but I know that one is there for sure.
It pops off but its on REAL tight.
There is one screw above the "Trash Bag Hook". Then it just snaps out. This is the DR Manual instructions: Makes it sound harder than it is.
(1) Disconnect and isolate the negative battery
cable.
(2) Remove the steering column opening cover.
(Refer to 23 - BODY/INSTRUMENT PANEL/STEERING
COLUMN OPENING COVER - REMOVAL)
(3) Open the ashtray and cup holder.
(4) Remove the one center bezel retaining screw
(Fig. 18).
CAUTION: Extreme care must be taken not to
scratch the ashtray door while removing the instrument
panel center bezel. Apply masking tape to the
ashtray door if the center bezel is not being completely
removed from the instrument panel.
(5) Using a trim stick C-4755 or equivalent, gently
pry the center bezel free from the instrument panel.
(6) Working behind the center bezel, disconnect all
electrical connectors and remove the bezel.
This is a picture of mine while out installing the gauge pod in the cubby hole. Not very good, if you need more pics out of manual let me know.
cable.
(Fig. 18).
RamWheelsBy4
Thanks Man !
More info and pics from the manual would be great
Are those BFG 315 All-Terrain T/As "E" rated ?
How much taller are those over stock. Look sweet
Thanks Man !
NoSparkplugs
17
05-17-2009 10:36 PM
Ace
06-18-2006 07:27 PM
03CTDCO
11-25-2004 06:04 AM
sstengler
11-21-2003 08:35 PM
