Air Conditioning Recirc Door Issue. (NO BLEND DOORS)
Ok, this subject has been around for a long time now. There is confusion between the Recirc Door and the Blend Door on our A/C systems. This makes searching for answers difficult when reading the threads.
These two parts do different things. Without getting into to to much detail, here are the basic symptoms of a Recirc Door problem: If your A/C is blowing normal temperature cold air but the volume is low coming through the vents and the blower (fan) sounds as if its working hard (blowing noise) then you have a Recirc door issue.
Also, if you have had a repair done at the dealer and they replaced parts behind your glove box without removing the dash and/or opening your A/C system, you had a Recirc door repair. Blend door issues are very involved repairs not to mention expensive.
The Recirc door repair is now a replacement unit with a better design that is supposed to resist breakage.
I went to the dealer today, took a tech two minutes to remove the glove box and diagnose the Recirc door problem, they orderd the new "improved" part and will put it in on monday. They said it should take no longer than an hour. We shall see.
Did I miss anything? Hope this thread helps any of you having this problem.
How many of you have "been there, done that" with this issue?
Conclusion:
The dealer called this morning. Turns out they had the part in stock, aperantly a customer had orderd it a couple of months ago and never picked it up.
So I took Dodge in and an hour and a half later the A/C kicks.
And it is MUCH quieter too, no more wind tunnel sound.
When I pulled out from the dealer the temp was 103F.
The truck cooled down to a comfortable temp within five minutes and I ran it on the second to lowest fan speed, recirc, dash and floor vents all the way home. Twenty miles nice and cool. My truck has never done that even when it was new.
27,645 miles
Customer states recirculation door is broken. Install special ordered part.
Removed dash, discharged AC system, removed HVAC box found recirculation door missing ( ) installed a new recirc door assy, installed HVAC box, charged AC, reinstalled dash, tested okay.
Here is the verbiage from my work order.
I had that problem every once in awhile it has not done that for a long time. but i just hopped on here to post a problem im having now and saw this thread.
The problem i have now is that it blows but NO COLD air. The wife and i took a 200 mile round trip a week ago. It worked fine. The next day hopped in noticed that the light for the A/C was not on, pushed the button and nothing. Pulled the dash part off to see if maybe it unpluged but nice and tight. Also on the same panel the heated mirrors are not working. You can up the blower speed but it doesn not change from bi level to defrost or the floor, just stays blowing out of the vent. Checked all the fuses, even pulled everyone out just to make sure. Hope someone can help or it will be making the trip to the dealer.
This may be a little off topic here, but my AC is blowing hot air, it worked fine last summer but got in it a few weeks ago and nothing but warm to hot air, went to wal-mart to get a recharge kit but the coupler does not fit onto the port, also tried to retro fit kit but to no avail, any help would be greatly appreciated. Oh BTW I have a 2004 2500 Cummins
I'm not sure why my post didn't 'post' yesterday, and it may be too late now, but here goes the question anyway.
My first Recirc door replacement took all day. When that door broke 6 months later, I just removed the door and have been without it for 2 years.
I have the new set (door, motor, housing) and intend to install it this month. Any idea on how it is done in an hour or even in the hour and a half they took on your's?
yeah, i have heard it is a much longer job to do the blend door. my truck is only about 8 months old, and the a/c has always been weak. it blows cold, but there is little to no difference between recirc and fresh. the motor blows like crazy and is very loud. all vent settings work, but i noticed the other day when i have it on recirc, it blows a fair amount of air throgh the front floor vents. any ideas?
Mine was broken at time of purchase too.
I was not watching over the techs shoulders but could see what he was doing to a certain extent. All he did was remove the glove box and some other dash pieces, removed the old unit and installed the new one. Re-installed the dash parts and that was it. He was in no hurry either...
I may just have to tackle this on Sunday and take pics along the way.
We finally had a reason to turn on the air conditioner yesterday in the truck (93 deg outside). I was very disappointed in the lack of "coldness" that is produced. It only has one temp when it comes to the cold. No cold, colder, coldest.....just cold. It seemed to work fine....just didn't get very cold.
Is everyone else with the new trucks seeing this, too?
Come on guys...
Read the original post, this thread is not about air temp. The Recirc door has nothing to do with temp. It has to do with where the air comes from but the problem it causes has to do with volume... not enough air coming through the vents.
Again, if the air is COLD but there is just not much of it, then you have a Recirc door issue.
