Advice requested for installing fender flares
Hello,
I've searched around for some info but not found alot. Here's my question.
I would like to install power wagon flares on my truck. See sig. My only concern with installing them is paint damage from slight movement of the flares during operation.
I know some people apply a film on the paint before installing the flares. Others have tape the flare to the truck.
So... what is the best method for the installing the flares to prevent paint scuff? I'm keeping my truck till the cows come home... so damaging the paint is not an option!
Thank you for any help!
I do not believe there is anyway around it, at least not if they are on there any lenth of time. Sand and road grime are going to get between the fender and the rubber flare gasket. Just have no plans of removing them once they are on.
Good idea using that paint protection tape! But I suppose it will scratch and look like heck too, and I hear it's a real bear to get off!
How about you have that bedliner stuff sprayed where the flares go and then mount them?
That probably defeats the purpose. If he is worried about the scuffing, he must plan on someday removing the flares, and having the original appearance. The bedliner coating would be harder to deal with than scuffs...
I used the 3M Protective tape when I installed my flares. Its been about two years and I have zero paint damage. This is the stuff and they sell it in 3" wide rolls. Works great.
http://solutions.3m.com/wps/portal/3...protectionfilm
sid
sid
sid
sid
I went w/ the Warn 4x flares ( http://www.warn.com/truck/flares/4x_flares.shtml ). They come w/ 3M tape to fasten the outside perimeter of the flare to the truck. The flares will stay on for the life of the truck, so I'm not worried about paint scuffing. The Warn flares provide a bit more protection (stick out a bit more) compared to the PW flares but are not obnoxious on a mostly stock truck.
Yeah, I just cut to length, used about a 2" wide piece, and then used a hairdryer to heat the strip up a little and molded it to the contour of the fender. I put the flare up first and used a pencil to mark my outline.
sid
sid
Thank you for the all the help guys!
Airslide
27
03-17-2014 01:17 PM
Eddy Reyes
32
06-05-2007 07:36 PM
Fisherguy
04-13-2006 09:17 PM
yermn
15
10-01-2005 02:21 PM
