Advice on removing / tipping the truck bed
I am preparing to do some tank mods (aftermarket fuel/lift pump, tank vent), but how to access the tank is the question. The options are to remove the truck bed or drop the tank. Dropping the tank when it’s empty or near empty will make dropping the tank straight forward. However, I am exploring the option of removing the truck bed – by ONE person, no lift.
I understand that there are some risks involved, but I’m sure someone has done this. After disconnecting the driver side tail light, removing the 3 driver side truck bed bolts, and loosening the 3 passenger side cargo box bolts, from the driver’s side can I tip the bed up about 2 feet? (which should be enough room to do the mods)
I can use 2x4’s to hold the driver-side of the bed up while I work on the tank. Or is there another way to prop up the bed?
Aside from the possibility of the bed falling, will the passenger side of the bed bolts hold the weight of the bed?
Administrator/Jarhead
If I were dead set about a one person bed lift, I would take out all the bolts, and get a small jack and jack up the bed, one side at a time, and block it up on the frame. Here's a pic for where all of your bolts are... there are only 6 of them if you have a short bed, 8 if it's a long.
I would defiantly recommend lifting the bed over dropping the tank... it makes the draw straw installation correct. If you have to drop the tank, support the tank as if it were in the truck, hanging, not flat on the ground, or your draw straw will be too short when you put it back in.
Get some guys to help you. Remove the bed! I was so glad I did it that way. Makes everything so easy. Just remember that if you drop the tank and put it on the groung the bottom of the tank will bow up and your draw straw length will be wrong. Do it on the truck and it makes it so easy.
Another option would be to unbolt the entire bed and then I would have to ask a buddy to help me slide the bed backwards and rest it on the tires.
.bOB and CRR - that's right, I'll call around and check.
All, good tips on things I should be aware of when dropping the tank.
1 Post
yea becare with the connections on the end of the hoses they are a booger sometimes and you can break something if not careful. you could cut a hole in the bed over the tank. seen guys do that on a truck or 2
Someone mentioned to me that I could remove the 4 bolts then loosen the last 2 (by the tailgate). Then I could jack up the front and block-it as I lift it. That should give me enough room to remove the 14" fuel canister, plus do whatever else.
we used a hoist and hooked the bed in the corners and lifted it off. alot easier than dropping the tank.
i installed my draw straw with a full tank, with the fuel in the tank bottom has pressure on it, so when you cut the straw i believe this helps with some of the 1/4 tank issues some guys have had. I have run mine down to nothing but fumes.
Have you got a tree or roof joist you can hook into? I put a strap into each corner tie-down. Brought them together and climbed into the bed with a come-along. Stood in the middle to balance and just jacked up the bed with me in it about a foot or so. Then drove the truck out from under the bed. A rented engine hoist would do the same. I think it is easier to pull the bed than drop the tank. I have done two tank drops and three bed lifts. JMO, Good luck.
