Added lift, head lights much better now.
Added lift, headlights much better now.
I noticed something the other day after lifting the truck with 1.5" blocks. The headlights now work much better. They actually project down the road instead of into the ground just in front of the truck. Now I can actually see well down the road as I'm traveling.
Did you install lift blocks on your front axle? I hope not, thats asking for trouble right there. It sounds like you did however, lifting the front would lift the lights and lifting the rear would lower the lights. If you want to raise your front end, I would suggest getting a 2" leveling kit. If you have blocks on the front axle, take some advise, get them out of there.
I don't think he lifted the front of the truck just to adjust the headlights.
The headlights are aimed low from the factory because these trucks are designed to pull some weight. The rear sags and the lights point upward. There is a lot to be gained by adjusting your headlights. The extra coverage is amazing.
Most 2" levelling kits are essentially blocks (spacers). There aren't many kits that replace the coils.
https://www.dieseltruckresource.com/...ad.php?t=92776
Bekim
nvr-enuf
04-22-2011 08:04 AM
jeeptjstud
08-31-2010 07:06 PM
rockcrawler304
60
05-30-2008 05:40 PM
klx650a2
01-14-2008 09:39 PM
Mark Hodowanec
02-05-2007 01:01 PM
