AC not working cold air intake rubbing?
Ok i have a question i have coldair intake on my truck and i was wondering if would cause my AC not to working
i pit on the amsoil 4090 and i think its rubbing
it looks like it is rubbing on the aluminum line but it doesn look like it has a hole in it yet is there any ways i can repair it with out it costing tons of money
Same problem with my 07. Took the cold ari intake off my 04.5 and tried to put it on my 07. Found the aluminum line in that area and the intake sheet metal would have rubbed on it and quickly wore a hole in it. Took a grinder and cut out a 3/4 square and put a piece of slotted rubber there and so far no problem but thought that it would have quickly worn a hole it the line if I hadn't noticed it prior to install.
will it work?
I had an issue in my 03 where the A/C wasn't working. After spending $400.00 at the dealership with another $700.00 trip scheduled for them to rip out the dash, I found out that having a FASS and a TST both grounded to the battery negative terminal would somehow cause the A/C to not work!!! I pulled one of the wires off and grounded it to the frame and the A/C worked great once again.......
Sleigher
05-04-2017 02:12 PM
Taquache
21
06-24-2012 03:11 PM
Dodgewincity
13
01-19-2008 05:41 AM
