AC freon????
Old 08-12-2007, 06:09 PM
  #31
CowboyDave's Avatar
I wondered the same thing. ^^^^^^ I just purged the system a little than added one big can and 1/2- 3/4 of a smaller can. Bumped me up to 35 psi and 57 degrees.
Old 08-12-2007, 08:44 PM
  #32
BgBlkTrk's Avatar
Looking at the maintenance guide, I guess up to 50psi you should be ok. I wouldn't worry about it too much though Helmutt, I am sure they include a bit of safety factor in there-as long as you are blowing cold air and your compressor isn't making any crazy noises.
Old 08-15-2007, 06:06 AM
  #33
JAXFL1's Avatar
BgBlkTrk & Cowboy Dave
Originally Posted by BgBlkTrk
C as long as you made sure you hooked into the low pressure side of the line, just keep putiing the freon in there until the pressure stabilizes. My pressure, before I started charging the system, was bouncing around from 0-40 or 50 (I don't remember how high but it was in the red zone on the gauge that came with the can) and finally stabilized after about a half a can of charge.
OK I give. Yesterday I bought a large can witht he gage on it and found the hook up for the AC line.... the problem is that the connector on the hose does not slide all the way down over the connection. How do you get it all the way down? If I hold the can right side up, I can hear the air but if I turn the can upside down it blows out around the fitting and the gets everything wet. Any ideas. I have a 2003 Dodge Ram 3500, the connection is on the left side of the truck between the radiatior and air filter box as you face the truck.
Old 08-15-2007, 06:21 AM
  #34
2500's Avatar
reading this thread is making me cringe!
someone posted a chart showing correct pressure for ambient temps.
follow it for best results.
it's possible to get too much refrigerant in system. if AC system is leaking down, best to find source of leak.
please consider reading a few HOW TO's posted in lots of places on WWW.
Old 08-15-2007, 05:12 PM
  #35
BgBlkTrk's Avatar
^^^^^ Well cringe on, but most people on this forum like to do the work themselves, and following a chart usually gives you the best result, but if a mistake is already made, you usually need to make a judgement call as to what you are going to do to fix the issue.
Old 08-15-2007, 05:24 PM
  #36
CowboyDave's Avatar
This is my go to site on the WWW.
genesis
04-13-2008 05:46 PM
sluggo42
11-28-2007 07:56 PM
90firstgen
08-01-2007 11:24 PM
linetrash75
13
08-24-2006 06:14 PM
robert chilton
17
09-11-2005 04:02 PM
Quick Reply: AC freon????
