6 way power seat repair info?
ANY info out there on power seat repair? Rear on driver side will not move up/down though motor makes noise.
Had no luck on topic search
Thanks
Thanks
I would remove the seat entirely to identify the problem. It's possible to remove the upholstery and cushions while its still in the truck but I think its easier to remove the chair completely first. IIRC its only 4 bolts holding it to the floor and 2 bolts to attach to the center section. Used working power seat units go for about $150 at salvage yards.
Most of the time when the seat motors fail to move the seats,it is due to the plastic gears within shearing off. There are two ways to remedy this common issue. One is to replace the entire seat base/ track assembly equipped with new motors riveted to it through the dealer. The base can cost from 475.00 to 585.00 from the dealer. An online Dodge parts wholesaler such as Allmoparparts.com is a good option as well.
The other method is to replace the individual motors by purchasing them from 2 men 1 garage. This is the most cost effective method that is easy to do yourself. Here is a link for your review. http://2men1garage.com/shop/category...aram=cid%3D%26
larrybartlett
07-13-2010 02:21 PM
DezertBum
03-10-2010 03:00 AM
Common
07-27-2006 09:46 AM
