305/555 trucks
Old 01-23-2008, 09:26 AM
  #46
D45
D45's Avatar
Originally Posted by Raspy
Simply look at the fuel filter canister. If it has a fuel pump mounted to the back of it you are still stock. If not you could have an in-tank retro or some other system.
John
What are the pros/cons of the in-tank retro version compared to the cannister mounted pump?
Obviously the cannister mounted pumps were a major problems, but did the in-tank version cure the fuel delivery problems (and make the truck more reliable)?
Old 01-23-2008, 10:09 AM
  #47
Hounddog's Avatar
Very few failures posted anywhere on the intank pump.Also if it fails(intank)its designed so the CP3 can still draw fuel and not leave you dead in the fast lane or at 3am.The engine mounted pump will.
Old 01-23-2008, 01:06 PM
  #48
C Schomer's Avatar
I've read that the intank pump needs cooling from the fuel and it's not good to go below 1/4 tank and that they still aren't enough for serious hp. It's hard to get to and expensive if it goes out. An aftermarket frame mounted pump solves all of that. Craig
Old 01-23-2008, 01:24 PM
  #49
Hounddog's Avatar
When its under warranty I'll go with the intank pump.
Old 01-23-2008, 05:03 PM
  #50
D45
D45's Avatar
I did check the service history on my truck, which revealed this:
April 12, 2007
45084 Miles
CHAMPION CHRYSLER JEEP DODGE
14500501 - Module, Diesel Fuel Pump-Cummi
I search around online and I believe this is the retro in-tank version.
Old 01-23-2008, 05:29 PM
  #51
MikeyB's Avatar
April 12, 2007
45084 Miles
Easy way to check is to see if a little round black canister is mounted to the back of the fuel filter canister. If it's missing the lift pump is in the tank.
MikeyB
Old 01-24-2008, 01:03 PM
  #52
HotRodK's Avatar
Talking
Since Im still new to diesels, can you go TOO BIG on a rail mount pump? I know you can get a 255lph inline frame mount pump for pretty cheap from the Mustang sites. Is there a preferred amount of fuel pump desired? 155lph? or as much as you can get??
Probably a dumb question, but I gotta ask.
dezl-andy
15
08-16-2024 05:09 AM
Locomotion
01-25-2005 04:47 AM
gullydog
08-22-2004 09:34 PM
Lsufan78
28
06-02-2004 08:06 PM
03CumminZ4X4
04-08-2004 04:58 PM
Quick Reply: 305/555 trucks
