2007 Gauge Dilemma
#31
What about trans temp? Any way to monitor that? Do you need to monitor that?
I also think we are adding that to our list, it is just not finalized yet.
#32
I don't know what year they started going with a trans temp warning light. But IMHO, idiot lights are just a notification that something has already failed in a bad way. Better to see it coming earlier with a gauge.
#34
I don't have a service manual, but tapping into one of the coolant lines is pretty easy. I can't think of a good reason not to monitor that.
The more I think about it, I really only want to monitor 3 things - EGT, trans temp, and maybe boost. An AM gauge set up for this is a bit under $400. That's more than BD's monitor, and a little less than the Scout.
I only want to monitor, not reprogramm. No power boosters for me; I have a warrenty to maintain.
#35
I'm in the same boat, I don't want a power adder. I've been looking at the monitors, but keep coming back to analog gauges. The monitors have an overly technical appearance to me, like something that belongs in a rice car. As for the analog gauges, I definately want to monitor EGT for towing, but I'm not sure if I really need boost and trans temp (Disclaimer - I'm still new to Diesels).
As far as boost goes, yes it looks cool, but what does it really show me? How much I am loading the turbo and thus how much load I'm putting on the engine? Won't the EGT gauge indicate the load based on temps?
My Titan had a factory trans temp gauge, it never got hot even towing 9K up mountain grades. I downshift on my own and slow down on the grades. I purchased the Maghytec DD pan to add more fluid. Do I really need to worry about trans temp when I don't anticipate towing more than 10K? Wouldn't the EGT's increase at roughly the same rate as the trans temp?
I can't figure out a good way to mount 3 gauges that I'd be happy with. I don't want to lose my handle (wife is 5'2"), and I don't really care for the look of the dash mount or steering column mount. I already purchased the SRT pillar. I'm thinking that I might be happy just monitoring EGT with a Pricol analog in the SRT pillar. If I went with all 3 gauges I was thinking about mounting the trans temp and boost down under the center dash section in single mounting cups, next to where I put my prodigy. The single EGT gauge sells for about $180.
Thanks,
Mitch
#36
For you guys who want to monitor EGT on a stock truck.. A couple words from experiance.. Your trucks will run soo hot it will scare you, its normal, but it doesn't seem right. 1400* happens very easily when towing, more if you let it. Both my dad and I had gauges on our stock trucks, we now run Smarty Jr's because of the super hot stock EGT's.. We didn't get the Smarty for the power, just the EGT drop..
#37
Boost is nice to have so you can be alerted to a boost leak before it causes a major problem. If you notice you're only getting 10lbs. where before you had 20 going up the same hill at that speed you might have a leak. Other than that, they are probably not really necessary.
#38
Also, the Scout is NOT a power adder and WILL NOT control ANY power adder on the 600 series and newer Cummins.
#39
I've definately got to get some gauges. Just haven't decided if I want to go back with a digital setup or go analog on this truck. Some good reading in this thread.
How much would you say that your EGT's dropped w/Jr?
#41
Since I've had guages I've never been anywhere near 1400, soon as I get in the red (1250 I think) I either ease off or gear down, and that's towing on the 'performance' setting on my Bully Dog.
#42
I have to really try to get mine over 1200* while towing.. and still it rarely happens.
