2005 Door seal torn at 1400 miles
Well I was a little surprized this weekend to find my drivers door seal torn at just 1400 milels, and I mean torn bad. I have a 2005 made in Dec/04, I have read all the posts about this problem (even before purchase) but "assumed" that new trucks would have the updated seals installed. Is this something they can fix, or will I be looking at this for years to come, has anyone had any success with the repair, I read the post about the door frames being bent out and will address that when I drop my truck off so it doesnt happen to me.
i've had 9 of them in 15k. the original design tears eventually, the new design doesn't seal properly. i have a newly installed old design seal on now and it's rubbing. no solution has been offered.
I had the TSB for the door molding done in December and I just had the drivers side seal redone because it was tearing again. I will continue to keep an eye on it until my warrenty runs out or until they come up with a fix for this problem. Went in Thursday to have the lower molding TSB done and they looked at me as if I had a %ick growing out of my head. "What TSB, we dont know about any TSB!" http://dodgeram.info/tsb/2005/23-005-05.htm Of course I had the TSB number and gave them the right explainations as to why it needed to be done. Of course they did not have the trim in stock so it's on order. It's supppose to keep all that road grime out of the lower door seal area.
we have our second set on the drivers side, the passenger side is perfect and i wonder why ? it is because they are two entirely different seals!!! go figure, i told the service writer to find the number for the passenger side and order one for the drivers side.weird...
Just got my drivers side done last week as mentioned. From the look of it, it seems to be different from the one they installed last time. This one seems not to catch the door edge. My passenger side is in good shape as well.
Oh yeah, less than 2K on my truck and seals are starting to wear a lot. Not torn through completely, but close. I'll be taking it to the dealer sometime soon...
I've noticed the 05 doesn't have the TSB listed for the door seals? Hmmmm
My '04 has almost 31K miles on it. Both doors seals are the original and show no wear whatsoever. A strange problem that is obviously only on some trucks. Wonder what the difference is?
I wonder if yours had the updated ones put on before the truck was delivered, a "smart dealer" would do this to make sure the customer was "completely" happy. Do you think you have more wind noise than you should, also can you post a pictureof the corner of your door. maybe we could see why yours didnt tear.
I know I'm jinxing myself but...'03 here, no tears, rips, or signs of it starting. 24k and still good to go on both sides. Bought it new in OCT 03. All I did was, when I first heard of this problem, was to rub some white lithium ball hitch grease on the seals. I only did it once and so far so good. But I bet they'll rip tomorrow .
I think it might have something to do with the door adjustment, i had new seals installed a few weeks ago, origionals wern't too bad but i was running out of warranty, had them adjust the drivers door a little tighter because of wind noise when on the highway, the wind noise has decreased quite a bit but the seal has already got a whole worn in it worse than the origional , the new seal was the same design as the old one.
rob
rob
Mine has been good since new, 1 1/2 years. On a friends truck his seals are torn badly. His seems to be made from a softer thinner material. I do use a protectant often.
Pete
Pete
