20" Dually wheels?
These are 19x 6.75. 20's gonna be hard.
http://www.customwheelsdirect.com/wh...l.php?id=59943
so are these
http://www.rimgod.com/Resalt.phpID=424
http://www.rimgod.com/Resalt.php?ID=425
Do some searching on the web. Most you're gonna find is 19s and the semi style rims.
so are these
NO one makes a 20" dually wheel. NO ONE. Your only options are
::: - 16" - Not sure if you can use on a 3rd Gen
::: - 17"
::: - 19" ( milled down 19.5)
::: - 19.5" The lowest profile tire for this is 225/70-19.5 = 31" i believe
::: - 22" (milled down 22.5)
::: - 22.5 (semi wheel must use adaptors)
::: - 24" (milled down 24.5)
::: - 24.5" (semi wheel must use adaptors)
Those are the only options as of right now
::: - 17"
I'll have to agree with GEN X, I haven't found any 20s for a dually either. I want somthing like a 20x8 so I can run a set of 35 inch tires. The 17 inch wheels that are available are kind of narrow, only 6.5" The 19.5s are a little wider at 6.75 but then tire choices are limited. The 22s (shaved 22.5s) are 8.25" wide but then the sidewall starts looking too low. for me 20s would have been ideal, too bad the market is not large enough for someone to make them.
kiszka6911
04-20-2010 04:18 PM
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
RobG
09-05-2003 09:13 AM
