100,000 Mile Preventative Maintenance?
I'm quickly approaching the 100,000 mile mark and will have some time off during the July 4th holiday to perform any preventative maintenance.
As I stand, I'm at 92k with my 2003 SO Cummins, 5-speed, 4x4. I've never had to do anything other than the normal oil/filter changes and a front & rear differential fluid change. The truck has been flawless. I have had no complaints and wouldn't have any problems buying another w/o considering GM or Ford.
Does anyone have any suggestions what I might want to look at having done to help prevent any future, untimely problems?
Thanks in advance,
Brian
Thanks in advance,
Brian
No transaxle I think he meant differential. It'd be a good time to go to synthetic differential and transfer case fluids. Also check belts and hoses maybe a new thermostat and radiator cap. Maybe a valve lash adj check and overflow valve. Tranny fluid/filter change and bands adjusted. ...Whoops I see you have a manual tranny, do a fluid change on it.
I changed out my differential to Redline at around 50k. I think that's synthetic.
I'm making a list, so thanks for the additional suggestions Abbynormal!
Originally Posted by HappyGA
check the blinker fluid level and change the air in your tires
Originally Posted by schorb
and i guess i should change out my spark plugs too, huh?
i guess there's just not a whole lot on these trucks you gotta do, huh? keeping the fluids in check and belts and hoses seem to be the most critical thing.
transaxle fluid? that's not the same fluid as in the differential?? i've never heard of changing the transaxle fluid....
On a serious note,
Yeah pretty much keep fluid levels checked. I woudl adjust the transmission bands if it has not ever been done. Maybe have the ole girl detailed for her 100,000 mile b-day. She has worked hard fer yah..
Grease any thing on the front end that can be greased. pressure wash under there to, cause you know the blow by bottle has dripped at least a little, and that is usually when you will see a leak or something is when you crawl under and pressure wash. That is how I found a tranny leak on my old 01.
