05 Steering Box Leaking! Why?
Old 02-26-2006, 03:33 PM
DirtEater's Avatar
My steering box is mostly oiled rather than dry rusty metal, and even has a very small drip that is hanging from the box itself. Anyone know anything about this? Is this an isolated problem or has anyone else experienced this?
And.....how much should you be able to move the pitman arm? It moves just a tad bit, and I don't know if that's normal or not.
Old 02-26-2006, 09:44 PM
tristan21's Avatar
There is a post on fixing your slop on the 3rd gen perf forum. Sounded like an easy fix on your own.
Old 02-27-2006, 08:19 PM
Crabjoe's Avatar
I don't know how often the box leaks but mine leaked and there's no seal kit for it. They had to replace the box, so it's not cheap.
Old 02-27-2006, 10:22 PM
DirtEater's Avatar
Might not be cheap, but shouldn't it be under warranty?
Old 02-27-2006, 10:29 PM
HdPower's Avatar
Mine leaked as well...they replaced it with a new box so far so good.
Old 02-28-2006, 12:36 AM
Betsy II's Avatar
My steering box leaked after 8 months, replaced under warranty. My power steering pump is now leaking, going in to shop tomorrow. I'm not sure the steering system is up to turning wheels with 2,200 - 2,500 lbs on each tire?
Old 02-28-2006, 05:51 AM
HdPower's Avatar
ON EDIT:::
I meant to say my steering pump was replaced for the leak not the steering box.
Old 03-01-2006, 01:51 AM
Betsy II's Avatar
Leaking Steering Pump
Dealer says seals are gone, new pump on order.
Old 03-01-2006, 07:31 AM
PanteraGSTK's Avatar
My roommate's 05' steering box started to leak after we went mudding/off-road he took it to the dealer and they looked under his truck and saw mud. They tried to tell him that since he took it in the mud they werent going to fix it. My buddy looked at them and said "so you mean to tell me that I can't take this 4 wheel drive heavy duty truck off road? I think I want my money back" they fixed his seals and hegot his truck the next day. (without replacing the box I'll have to tell him yall got your whole box replaced)
Old 03-01-2006, 08:37 AM
DirtEater's Avatar
That's unreal! That's the kind of crap that they may tell me. "Due to the 35" tires causing excessive strain on the steering box sir, we're unable to cover your box under warranty".
Old 03-01-2006, 09:45 AM
StrokeThis2500's Avatar
i had the same problem is ur powersteerin pump if ur lucky the dealer will have it i was told they were on NATIONAL BACKORDER but my dealer so happened to have the last one
Old 03-01-2006, 04:50 PM
SOhappy's Avatar
I was changing my oil a couple of days ago, noticed a drip coming from the steering box too. Checked the fluid and it was down to the "add" line.
Funny, when I cracked open the power steering dipstick to check it I heard a "FFFFFFPT" like it was under a lot of pressure. Wonder what's up with that?
Have had ZERO problems with my truck in 31,000 miles. I guess something was bound to happen.
Old 03-01-2006, 09:44 PM
CATCRACKER2's Avatar
almost every 3rd gen i have ever looked at leaked no big deal though i would not worry about it
Old 03-01-2006, 10:14 PM
Crabjoe's Avatar
I was over the 36K miles so no warranty on it. I had to pay to have my death wobble fixed also.
Old 03-02-2006, 06:55 PM
Ramcam's Avatar
I had what i thought was a leaky steering pump.Took it in a couple of times but they couldn't figure it out .They replaced the pump but it still leaked.I went back again the service manager came out and released the pump reservoir.The cap blew up into the sky.We put a new cap on the reservoir that had pressure bleed holes that were working and it has'nt leaked since.
Quick Reply: 05 Steering Box Leaking! Why?
