05 with 37K,clunk or "pop" in front end?
My 05 ram has developed a loud pop coming from the front end when I am driving it,seems to do it when turning or pulling into driveways etc.I had a quick look and the tie rod that bolts to the steering arm seems to have some play as well as the track bar where it attaches on the lower pass side.i went to the local parts store and they didnt have a listing for these parts under MOOG,are these dealer only right now?What else might be making the noise?I should mention I have a 6inch top gun customz lift kit on the truck as well as 37inch toyos,thanks!!
Have you also double checked all your bolts after doing the lift?
I had a little knock noise going over bumps at slow speeds, one of the upper control arms had come loose, quite a bit actually.
I went over ALL the bolts on the front end and found a few that could stand to be tighter, it firmed up the front end, no more noises...
Also too, check your ball joints(jack up one front wheel, check for up/down play)
my truck is stock height and stock tires...seems to make the same noise @ 30K...ONLY when turning left @ low speeds
i got under the front end and wiggled everything by hand..nothing moved even slightly...so i have no clue what it is
guess it wouldnt hurt to climb under there and just torque the bejesus out of everythin on the front end though.
I've replaced 3 tie rod ends in my truck, replaced the same one twice in the past 10k miles....ironically all of this started right after my leveling kit was installed.
Im going to get under there tomorrow and double check all the lift kit fasteners first and change out the steering arm tie rod.I bought one for a 04 as they didnt list an 05 one,anybody know if they are the same or have the moog part #s for the 05 tie rods and track bar?973604x4,which tie rods are wearing out?
Well I retorqued everything(nothing really was loose) and the noise seems to be gone so far,If it is gone I,m going to assume I hadnt "killed" the track bar bolts enough the first time.thanks guys!
Jamie
Cummins610
17
05-29-2010 12:50 AM
MasseyMan1089
05-23-2007 07:56 PM
Gypsyman
08-27-2004 04:32 PM
