$ 775 for a headlight out ?????????
I replaced the blub with no luck. checked the plug into the blub and no power. Took the truck to the dealer............The front light power module is out and they say the power module is bad too......The front lights all work except the driver side low beam, with the lamp out on the dash on..... The parts were not on hand and they are ordered. I needed the truck so I picked it up. Now the question : how would the front power module work except for the one low beam, if the power module that feeds it is bad. wouldn't the front module not work if the power was bad... AM I CRAZY or are they ( the Dealer ) tring to take me for a ride ??? Did I mention that the parts are $ 669.00. Anyone have any thing on this or simular experinces ? I paid the $ 109.00 to have them put the truck back together so I could drive it and the National back ordered can parts come in. Why are they on National back order ? Is this a problem that dogde should be handling ? Help $ 775 for a head light that woul not turn on ??????
For that kind of money, I'd rig up my own setup with a relay and such and live with the lamp out light... Probably can be done for under $20. That's really crazy...
I can only go by my '05 manual, but he '04 may be the same. The manual shows a "left low beam driver" in the Front Control Module, which appears to be located in the Integrated Power Module. The driver is likely a power transistor, which probably has failed. I'm sure the driver is controlled by a signal from a microprocessor.
I have a problem with the degree of computerization on these trucks. Everything is computerized. I understand the need for computer control of the engine and perhaps the auto trannys for emissions control purposes, but computerizing all the other vehicles systems, to what end?
These things now take a scan tool just to check the lights, and the costs are horrendous, as people are finding out. If it was my truck, I would have that module out to see if I could get it apart and repair it, but I have an electronics background, and most people don't.
I don't know what's going to happen with these vehicles as they age, and the cost of repair "parts" is going to become a bigger and bigger percentage of the truck's value.
Either Dodge should have made these modules bullet proof, which they clearly haven't, or they should have designed a simpler electrical system in the first place.
The relay idea will work. Just use a fused power lead to the relay, and wire the coil to the right low beam. In case you are considering it, don't wire the left low beam directly to the right low beam, though. That would likely burn out the right side low beam driver as well, due to excessive current draw.
Yeah, dont let them keep it. There must be half an ounce of gold in there. Hope you find a cheap fix.
Don M
87
12-22-2013 11:05 AM
mtdoragary
11-07-2013 08:31 AM
five20too
03-15-2009 04:33 PM
Bean
09-25-2008 04:06 PM
jlipskoc
10-24-2005 01:16 PM
