Where Is The Fog Lamp Relay
It might be J10 /lightbar offroad lights
Foglights Will Not Work
Just Added Foglights To My Truck 2009 2500 Dodge Ram 6.7 Diesel Used All Dodge Componets Still They Will Not Turn On Do I Have To Do Something Else Cannot Find Any Relays For Fog Lights
I went thru this same thing on my 04, mine had the harness to the front of the truck ( did your truck have this) so I got the switch, the lights and brackets and harness between the lights from a wrecked truck. Did the install and no lights, in the power center under the hood on mine it showed the number for the fog lights relay and it was there but no power to the relay, long story short the fuse was bad. From what I saw for your truck I believe in your power center you should have a relay in the J10 slot .. I believe it says lightbar/ offroad lights not sure where the corresponding fuse for it is.
screamin01
08-29-2010 01:02 PM
