3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Stackin a 6.7 and how to get 600 hp
Old 07-08-2008 | 11:50 AM
big_bear_92007's Avatar
What would be the best stack for a 6.7 and what would i need to do to get 600+ hp manual transmission
Old 07-08-2008 | 11:52 AM
Sloverado's Avatar
It most likely won't happen with a stock charger on #2 only. But the Hot Edge and MP8 would be a good stack right now with a DPF delete and EGR delete.
Old 07-08-2008 | 01:32 PM
well my roomate has plenty of money to blow and he wants to know what all he can do to achieve it
Old 07-08-2008 | 03:03 PM
GlennRMK's Avatar
The had one in Diesel Power that made 600 hp. I believe it had FASS, injectors, EGR and DPF delete, SPS62 and EDGE Juice.
Old 07-08-2008 | 06:21 PM
OldSmokey's Avatar
Do the 6.7s need different turbos then the CR 5.9s? Im thinking about getting one but want to run the twins that Im building on it
Old 07-08-2008 | 07:19 PM
highrpms's Avatar
It is challanging to get to 600hp on #2 only. There have been a few, but it is not as easy as a 5.9. The tranny upgrades are partially here, but there are only torque converters, no valve bodies yet or billet shafts. I here Sun Coast is almost ready to offer a complete 68RE.
Tuning with a PMT, Edge, an MP8, EGR delete and DPF delete is good to 450hp at this stage of the game while keeping EGT's in check. Torque at 450hp would be 1000 ft lbs or more.
I think Industrial injection can do some stuff with the VGT turbo, but that is a weak link. You can also do injectors, but you will have EGT problems easily and I do not know of any CP3 mods yet.
It is too early, but the 6.7 should make good HP with very high torque numbers.
Old 07-08-2008 | 11:35 PM
97DodgeRam's Avatar
You need to try to talk to Raw Diesel. I talked to them at a truck pull about a 6.7 and they have one set up almost like a 5.9. I almost went to watch it pull, but the pull got rained out in Stanford.
Old 07-09-2008 | 02:14 AM
jmccart's Avatar
I keep waiting for the 6.7's to all start get "figured out" and start making big power. It will be interesting I bet.
Bigbc1
02-25-2010 10:51 AM
Redliner
03-07-2008 04:47 PM
genros
12-25-2005 10:46 PM
SjLingenfelter
09-09-2004 03:39 PM
