Smarty S67 SIM/EGT sensor FREE software update
First of all, I apologize for having been silent on the forum for a long time lately! We strive to deliver the best possible product's / software's. The time needed for the R&D can be rather long.
It's either time dedicated to the forum(s) or to the R&D. I choose the latter one...
Attention current and future Smarty S67 owners:
Based upon our customers feedback ( A hugh THANK YOU guys! ) we have found over time that
the EGT probes / SIMS did create several problems on about a 10% of the trucks that were using our product. Those problems were due to the vide variation in tolerances between sensors / SIMS and the ECM's themselfs. Thus we immediatly started the research and development for a possible solution.
To keep a LONG story short, we have now completed the testing and validating of our brand new SIM / EGT sensor FREE software! Starting from today the new software update for the Smarty S67 is available on our website for free download.
Also the “deletes” instructions have been upated with the revised version for the SIM free version..
In short, simply unplug the EGT sensors / SIMS and seal the connectors with electrical tape.
Altough, the sensors / SIMS could remain plugged in we still would like you to remove them. Simply because under certain circumstances ( for example shorted wires in the SIMS/Sensors ) they could still cause problems. For a more level “playground” please remove them !
Since we were at it... the option in the ME software to turn the DPF/EGR on/off has been causing us some grief. Read, we have had a few complaints from customers that DTC's with the ME software still poped up. Turned out that they did not turn the DPF/EGR off. Well, it is the way it is , so we choosen to change. Unless returned to stock software, the ME software now turns the emissions equipment off. Period.
At the same time we had started the testing of a new software for the stock trucks without deletes too. The main goal here was to improove the mileage compared to the previous software versions.. Another long story in short version , accomplished...
All software's do now enable the manual high idle ( using the CC buttons on the steering wheel....)
both for the automatic and manual trucks. Only, on the manual trucks a pin on the ECM needs to be grounded through an additional brake switch. Before you ask the question..., of course it is possible to enable the high idle without the need for an expensive OEM switch, simply grounding the wire.
Yet, for liability reasons we can not provide detailed instructions but they're easily found in the various forums.
In addition to the above, a lot of fine tuning in all the software's has been done. Way more that what could be mentioned in a “short” MSG. Just to mention a couple , the turbo boost pressure has been revised for better mileage. The codes for a disconnected stock turbo have been deleted ( ME version ) the list is long...
Thanks again to all our customers for their continued support. We look forward for your feedback about this latest software revisions ! ( BTW “R12” )
Marco
Marco
Gentleman,
I'm sorry to say, we have a small problem with this latest software "R12ME". Code P0489 was not dealt with correctly. Thus the code could still pop up.
A certian guy called Marco did screw up.
OPS!
Good news is, I have already corrected the problem and the new software is published on our website. Since the correction deals with a "minor" problem ...
Instead of going to version "R13" I preferred to do" R12me". Where the "me" is in lower case instead of upper case.
If you did not get the P0489 there's no need for you to update your Smarty! If you got the code, well it's time for another update session.
Sorry for the inconvenience!
Marco
OPS!
Marco
"California Style"
Found it
I can't seem to find this information on the MADs site:
Found the information in the downloads section after saying yes to the agreement...
ctzdavis
07-09-2012 04:02 PM
alboy
11-27-2010 04:11 PM
Lary Ellis (Top)
94
10-28-2009 08:59 AM
