3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Smarty Jr vs. Sr
Old 02-09-2012 | 06:50 PM
Blake Clark's Avatar
I used to do it the same as mega-engr.
However, it wont hurt to load the programming first, to make sure it loads properly, and then delete hardware. Would suck if the program wouldnt load, and you have a full deleted truck.
Old 02-10-2012 | 05:49 PM
mrweasel's Avatar
Hey Blake and Mega, are there any exhaust gaskets I need to get before installing the DPF delete pipe? I looked on auto shop web sites and none are listed and of course a gasket didn't come with my order.
Old 02-10-2012 | 05:55 PM
mega-engr's Avatar
"California Style"
Blake has a good point on the programming first, before the deletes, as we've seen people struggle with this area who may not be computer savy or just run into some technical issues.
I just reused the stock pipe gasket. And, I've had to take remove the delete pipe, put back to stock and then add the delete pipe back in again (thanks to the smog test BS). So far, so good.
I'm sure someone will direct you where to find or just go to the dealer...
Old 02-10-2012 | 05:57 PM
mrweasel's Avatar
Thanks, will give it a try.
Old 02-11-2012 | 02:44 PM
mrweasel's Avatar
Hey guys, quick question... doing deletes now and wonder if I need to unplug the sensors on the CAT if I'm just doing the delete pipe. Thanks.
stock03
34
04-21-2011 07:40 AM
RyeThomas
40
04-20-2007 10:12 PM
BigBlue
11-22-2006 02:46 PM
bnold
39
06-04-2006 08:21 AM
CTD_Neil
02-23-2006 09:27 PM
Quick Reply: Smarty Jr vs. Sr
