3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
How Loud Is A Downpipe?
Old 08-31-2010 | 05:34 PM
EverydayDiesel's Avatar
I already have a DPF delete pipe and I didnt notice much difference when i took the DPF off.
I was curious how much louder my truck if I replace the factory down pipe with a 4" downpipe and keep the stock muffler?
I dont like it too loud since I take long trips. Does anyone have any sound clips?
Old 08-31-2010 | 05:41 PM
Blake Clark's Avatar
I can tell you its not gonna be loud at all. That is how mine is currently set up and the only time you can hear the exhaust is in 6th gear lockup under 50mph. You know, when it lugs it a bit, and then its barely even noticeable. If you're looking for not loud, this setup will do you fine.
Old 08-31-2010 | 06:00 PM
got_soot's Avatar
Soot For Brains!
I doubt if you would notice a difference. These trucks straight piped are actually quiet!!! id say you would love a mbrp 5inch exhaust system with a muffler!!!! its not loud at all and it gives it a nice tone!!
Old 09-16-2010 | 09:25 AM
Mike Holmen's Avatar
The Guru
Mines slightly louder than stock, but only the smallest amount. I just removed the DPF/cat, the rest of the exhaust is stock. Sure helped on turbo spool-up and gave her a wee bit more power as well.
Old 09-16-2010 | 10:41 AM
Lil Dog's Avatar
I am contemplating putting in the downpipe to get rid of the DOC as the final step. Compared to my FIL's 2010 side by side, the rumble is more apparent without the DPF/CAT but not like straight piping the older versions. I do get more of a drone in the 2200 RPM range with RV in tow on hills, but its not that bad.
97catintenn
07-12-2009 05:33 PM
wannadiesel
09-09-2004 08:45 AM
KatDiesel
06-02-2003 12:11 AM
97CTD
02-04-2003 03:05 PM
patriot pearl blue
12-15-2002 12:10 AM
Quick Reply: How Loud Is A Downpipe?
