Is the H&S Mini Maxx defuel causing CEL to come on?
I am working on a deleted 2008 6.7 with around 45k miles on it, using a mini maxx tuner. I have set the defuel for 1200 on egt. It beeped about the egt when pulling a loaded goosneck, then threw a code for P1011. I may have the number incorrect but it was about low fuel pressure when I looked it up. I changed the fuel filter, trying for the easiest/cheapest solution first. The truck ran fine, and taking the trailer home it beeped again about the egt, and this time threw two codes : the same low fuel pressure one, and one referencing low rail pressure.
Is the defueling causing this, or is it a legitimate fuel pump issue? I did not install a shim or plug in the rail. The truck is fully deleted with a 5" tbe and pusher intake. It has a stock airbox and filter.
You will need to put in a fuel rail plug. H and S makes one I think it's around $50. That would also be a good time to replace the intake horn. I have my EGT defueling set at 1400 and tow at no power or set on mild with no problems.
2008, 3500 SRW, Black Max Mini Max, H and S EGR delete TBE 5" Diamond Eye with 6 " MBRP tip,
shlen
12-21-2014 12:22 AM
jlambert
11-02-2011 03:26 AM
Jagsfan811
08-28-2011 05:28 PM
2006BLKMegacab
01-15-2011 01:33 PM
