Fluid Damper???
Fluid Damper???
What are fluid dampers and what do they do? is it worth getting? they are saying up70+ HP and 30 lbs torque... please help me out lol still a noobie,
Thank you much for your input
Jpw,
Jpw,
I don't know if they make one for the 6.7 yet. It basically takes out the harmonic vibrations out of the rotating assembly. I don't think it'll give that much extra power, but it'll help keep your motor happy for a long time.
They dont claim 70hp, or 45hp. Fluidampr claims 4-5 hp on an other wise stock truck.
I have one on my truck and its great. A must for the modifcation list.
The 6.7L has a silicon filled stock damper so a Fluidampr is not needed in my opinion.
Its easy to change,, but the belt can be a bit tough. On the box that mine come in it said up to 45hp gain,,,, but I cant say that it is true, or not true
Kevin
Kevin
and how much is a Fluid dampener aftermarket??
maybe a stock 6.7L dampener would be a cheaper alternative with the same results????
what do you guys think????
Along the lines of dampners, is there an underdrive pully system for the power steering, that anyone has seen???
My truck seems to resest having the wheels turned while at idle. It's fine if I start to move, but sitting as in a parking lot, it seems to bog down some.
