Drop in K&N.
Search aound this and other sites as this has been covered over and over..
I do believe most items I have read try to steer you away from K+N.. Then you will read from others that swear they have had them in use for years without any trouble.
I chose not to use them in my diesel but have used them in cars with good results. I am using an AFE dry filter and have had good luck.
You are asking a question that will probably get you both Yes and No answers.
Best of luck with your choice as that is what it will come down to.
I used a K&N drop in once in my 03 for a few weeks until I heard someone mention that the oil residue can be sucked out of the filter and through the system. Sure enough, when I checked at the turbo, I could wipe a oil film off the fins. I will never use a oil filter on a turbo diesel again. My 6.7 is still stock but I will soon be installing a S&B or AFE. I had a AEM Brute Force on my 5.9 and really liked it. I have not found one for the 6.7 yet.
the K&N is good for this obama economy, it keeps mechanics and parts suppliers in work. cummins has had warnings out for two decades now and Chrysler will not warranty a dusted engine from a K&N and all independent lab reports has K&N at the bottom of filtration. a person would have to have dung for brains to use a K&N on a cummins.
Well Carl,...I guess you can put me in the category has having "dung for brains" because I have been using the "K&N Filters" in my 1996 Dodge CTD 12 valve for the past ten (10) years now! You and others here can read my "signature" for how my 96' is set-up but to give "the other side of the story" I have NEVER experienced ANY issues with these filters Sir!
I do regular oil analysis' as I drag race my truck alot and also use heavy water injection to keep my engine cool. For your informatin, I have NEVER had a oil analysis come back with any alarming levels anywhere! And this is sometimes with the oil having 3,000 miles on it!
Now, with that being said, the oiled "K&N Filters" are NOT considered a good option in the new Dodge/Cummins 6.7 Emissions Engines due to the fact that the oil fouls the sensors in them. But, I wouldn't own one of those anyway!
John_P
In my opinion K&N and others are ONLY good for carburetor . Or non turbo diesel motors
K&N oil gets onto MAF sensor on F.I. motors.
Turbo diesel the K&N oil gets on the turbo blades & intercooler.
EDIT chevy SPFI your can use a K&N on cause its like a carb.... EZ to clean
Ron R
09-16-2008 11:09 AM
surfram
0
02-19-2007 09:12 AM
Cummins600
02-26-2005 04:43 PM
