DPF delete almost complete
I have acquired another cat and DPF, which I have cleaned out to act as a straight pipe, however maintains a stock appearance. Does anyone know what the part number and where to buy the bolt that the sensor line fits through and screws into the dpf bung holes.
I am getting ready to weld them shut, however, if I have to return the truck to stock, I need to replace one fitting to go back into the stock DPF that remains fully intact.
to be clear, I have two DPF's, one that is gutted and the other which is original and 100% working order.
Thanks
Chris
Thanks
Chris
http://s889.photobucket.com/albums/a...3.jpg&newest=1
Here is the pic. I circled the two area in red.
Madhat, yes only tool about 1.5 hrs to get it all changed out. However, I stripped one of the pressure line connectors on the DPF and still need to plug the holes.
Thanks
Chris
Thanks
Chris
Looks to me like a 1/8 NPT plug. If if is, try running a tap through it to clean up the threads and see if a plug will fit it.
I did the same sort of thing with my cat on my 03' Hemi. Used the shell of the cat with a straight pipe inside.
Not a bad idea for my new Cummins in California. They're just doing visuals right now.
king cotton
11-24-2010 10:33 PM
reaves11
05-22-2010 10:24 PM
Red3quarter
11-08-2008 04:11 PM
Ghost Ram
13
02-10-2008 11:48 AM
