clutch slips w/smarty on #1
Hey there... g56 71k on stock clutch..I run smarty on #1 fuel economy, the clutch will slip going up a grade with little or no load anywhere from 50mph up...i'm very easy on this truck..I know the stock clutch is the weak link..looking for opinions..thanks........
Yeah... I'm running the smarty jr also. First time I got on the throttle I heard a hellacious noise! Pulled over, checked all my new flo pro exhaust mounts & connections, they're tight. So off I go again. Half throttle aggresively, tons of noise and vibration, rpms jump to 2300! Tire spin? Nope! Gotta be the clutch with only 30k miles on it now! even just motoring down the highway, pull out to pass, I gotta ease into it or she slips! Southbend... Here I come!
"The dual mass systems are designed to transmit less engine vibration to the driveline, and give a better more car like driving experience. They also reduce some of the jarring and stress on the transmission and remainder of the drivetrain. They work fine as long as the engine remains unmodified and the vehicle is not used/abused beyond manufacturers recommendations.
As soon as you start to increase the engine power over stock, or load the vehicle beyond design parameters, you run into problems. Dual mass flywheels are tuned systems and must be matched to the engine torque curve, engine resonant characteristics, vehicle load curves (including axle ratio/tire size calculations). They work by having a set of springs inserted between two rotating masses (thus dual mass). The springs are sized to soak up some of the resonant vibration from the diesel engine under load conditions. A dual mass fly wheel generally also contains an over torque friction release, so if it gets suddenly overloaded, rather than damage the springs, it slips. This works fine as a safety valve, but if it does it much it burns up. In short, overloaded they burn up and the springs get destroyed and they are worse than if it were a single mass FW."
I had the exact same problem with my 08, it had 40,000km when I put the smarty on it and the clutch started slipping right away. I went with a dual disk southbend clutch and ended up having a lot of issues with it. (you can read back in my posts). Ended up finally settling with a single disk southbend after $1000s of dollars and warrenty issues. Not knocking SB but I would look around, do your homework....maybe mine were built on a monday.
