3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
boost gauge install??
Old 01-12-2012 | 10:41 PM
baddodges's Avatar
What size tubing and connectors do I need to install my boost gauge? Thanks
Old 01-14-2012 | 03:22 PM
Blake Clark's Avatar
If you bought it new it should come with the tubing and connector. What type of gauge do you have?
It will require a 1/8 NPT threaded hole somewhere, most guys use a boost bolt. You could tap the intake horn, or easiest place, if deleted, is the EGR blocker plate.
I used a boost bolt on my 08 and had gauge fluctuation issues, on my '11 used the boost bolt till I put my intake horn on and had no issues.
Old 01-14-2012 | 06:02 PM
carl48's Avatar
get a oil pressure gauge installation kit.has all fittings and 6' copper line. if you have not wasted your money on a gauge get a glycerine filled 0-60 psi gauge from ww granger for about $17 i make my own bolt but genosgarage.com has them for $7.50 here is a pix of a surplus center gauge
Tank_66
02-28-2008 08:34 PM
latitud_rt
03-24-2003 11:31 PM
DawgII
03-10-2003 07:15 PM
soundfetish
02-26-2003 02:37 PM
Quick Reply: boost gauge install??
