3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Aftermarket oil filter system needed?
Old 06-24-2011 | 10:50 AM
jlambert's Avatar
My 08 is just about to 100k miles. I want a "million mile" truck and extra power is secondary. I plan on getting a tuner and doing all the deletes, adding a Fass system for the fuel, a Snow MPG-MAX water/methanol injector and delete tubes for the cat and dpf. I tow a fifth wheel out here in flat but VERY dusty west Texas. I do an oil change every 3k to 4k miles. Again, I want this truck to last forever and I'm wondering if I should consider an aftermarket oil filtration system. What do you guys think? Thanks for your input.
Old 06-24-2011 | 03:59 PM
klx650a2's Avatar
I would run the Fleetguard Stratopore oil filter on the truck with a centrifuge bypass. No filters to ever change on the centrifuge, just clean out the crude once in awhile.
Old 06-24-2011 | 05:50 PM
f419sr1's Avatar
Iv never seen the centrifuge bypass. Sounds nice not having to change filters. What is the micron level it filters to? Im using a Amsoil bypass that filters to 2 micron
Old 06-24-2011 | 06:02 PM
Fiftygrit's Avatar
I just run the donaldson oil filter, change every 8k miles with an oil change, I did oil tests for a while and they all came back just fine so I have stuck to them. And the best part is that there right around $12 bucks at Freightliner trucks, they do service on highway trucks with Cummin`s motors
Old 06-24-2011 | 06:31 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
That's the one I use. Seems to be the most practicle solution
Old 06-24-2011 | 06:38 PM
cbrahs's Avatar
http://www.oil-tech.com/dodge-cummin...er-install.htm
Old 06-24-2011 | 09:06 PM
f419sr1's Avatar
I couldn't find any information on the filtration. Their are no specs that I could find. Im sure they are there I just didnt find them
RiverRat2
10-15-2019 10:59 AM
scow1
03-03-2009 07:41 AM
I PASS GAS
03-16-2006 07:59 AM
Ramasaur
04-23-2004 06:31 PM
Quick Reply: Aftermarket oil filter system needed?
