Yet another turbo thread
Ok first off, I know little to nothing about turbos. It seems the more I research the more confused I get. I have been reading all the threads and talking to lots of companys about turbos, so one of you turbo guru's please just tell me what to buy. I ultimately want somthing(s) that spools relatively quickly and is capable of 650+hp. I live in Colorado at about 5000' in elevation, so from what I understand getting a single to make that kind of power without a lot of lag is impossible, leading me to believe that compounds are the only way to go. So if any of you have any definitive setup/kit to go with please let me know.
Hx35/Ht3b setup should spool quick and get you in the 60psi range more then enough to support 650hp and if you end up needing to upgrade go to a super hx40/ht3b. Or if you want to go the single turbo rout go with a silver bullet from industrial injection.
Ok first off, I know little to nothing about turbos. It seems the more I research the more confused I get. I have been reading all the threads and talking to lots of companys about turbos, so one of you turbo guru's please just tell me what to buy. I ultimately want somthing(s) that spools relatively quickly and is capable of 650+hp. I live in Colorado at about 5000' in elevation, so from what I understand getting a single to make that kind of power without a lot of lag is impossible, leading me to believe that compounds are the only way to go. So if anyone has any of you have any definitive setup/kit to go with please let me know.
Shane
