Xzt2 Good Or Bad
I think the standard is a better option because you can run the milage program and then adjust on the fly if you need more power. You can only do that with the XZT if you add the Commander.
Depends what you want and are willing to risk. I have a stock tranny and tow sometimes so I opted for the xzt for a few reasons over the adjustable standard. The xzt was designed for towing and low end power. It is very safe at 65 hp and doesn't give you the option of burning out your tranny with higher settings. It is less money to buy and does as advertised - on my truck anyways. I like that it's plugged in under my dash and I don't worry about switching levels or anything. It's like it isn't there and makes the truck drive way smoother with a good bit more power. Simple but effective.
If you get the X2 Xzillaraider, you have many different download options if you choose to use more power & it comes adjustable on the fly w/the pod that it comes w/ that also monitors coolant temp., rail pressure, & boost. You can also get the upgrade Race version for $80 more that gives you 6 different levels to choose from. There is one in the classifieds for sale that is already upgraded to the Race version.
I have the X2 XZT version and have been happy with it. I can program via USB with multiple program downloads from Quadzilla including the mileage max city and hwy or the standard 65hp 165tq code for towing the toys.
the dude
01-15-2008 09:57 AM
csxt665
01-12-2008 01:25 PM
jballou
12-19-2007 05:22 PM
dkws04
10-29-2007 04:24 PM
surfram
10-28-2007 09:08 PM
