XZT or power puck? Why?
O.K. if you had to do it all over again OR have used both which one would you go with and why?
Just learning and need some information from those who have used them. I like to install stuff on other guys trucks and need info so I can give better info.
Thanks guys,
Thanks guys,
The XZT does boost fooling, the Puck doesn't. The new XZT is upgradable and programmable, the Puck isn't. Some get better fuel efficiency with the XZT, and the Puck won't help you with that.
The Puck is switchable on the fly, the XZT isn't unless you have the Commander gauge set. The Puck is a lot cheaper.
I liked the switch-on-the-fly aspect and I already have a quad boost fooler, so I have the Puck. I like running without a box better than either one though...!
I had XZT and it never threw a code or anything, was perfect, also got best mpg while I had it. Also xtra ? 140 ft. lbs. torque. Could definitely tell it in seat of pants. Would have it now but got another Quad product. Of course the reason I got another Quad was not only the product, but the UNBEATABLE SERVICE. Don't know squat about a puck.
BIGDAN65
16
01-23-2008 10:02 PM
Stainless
11-01-2007 10:53 PM
06megacabman
05-15-2007 04:28 AM
