xzillaraider rp gauge
i installed my quad xzillaraider 2 and love it. i was just wondering what i should see as far as rail pressure numbers. at idle it jumps from 500 to 800 then driving its like between 1400 and 1900 then when i get on it i see higher 2000's the highest i have seen is like 2900. thanks for any info
Jake H.
Jake H.
of the research i have done it seems if you added a zero on the end of my readings the numbers match up well. is it just that the control pod doesnt read to tens of thousands???
Jake H.
Jake H.
thank you very much vzdude. i just got back from a drive and realized that it only went up to four digits and the screen was filled up.
Jake H.
Jake H.
Yep sounds good. I'm @ 692-740 idle I've never seen it above 25k ish even on 100hp. Cruising down the hiway @ 70mph on 60hp I'm around 18-21k depending on my foot.
usmcduncan001
09-14-2007 04:10 AM
gatf4
24
03-30-2005 11:45 PM
james satterfie
03-25-2005 01:48 AM
GBB
03-24-2005 09:53 PM
