Xzillaraider 2 Product Info
#31
Well, seeing this and that it works with 06.5-07s, it looks like I just found a box to stack with my Smarty!! Finally somethin for my truck...was contemplating current Race, but Im thinkin Ill just hold off for now...cant wait!
#36
Once this becomes available can we do a sign-up and do clusters of 20-30 boxes? I have been thinking about this and all I can say is I feel bad for you. The # of boxes out there has to be huge!
#37
...Ok, first lets talk about the USB updatable download page. We already have a large database of files. Each module has a “model” programmed into it as well as your serial #. This keeps you from accidentally downloading the wrong set of tuning files into your module. There is a nice tutorial that you will pop up on your first time to update your module. This installs the drivers for you. Once this is complete you will be able to update your module in around 15 seconds or less.
...Each tuning file will put a “feature code” in the module. This allows you to use your update application to check and make sure which file you are running and any given time. Just plug it in and click “get module information”. You will see the model, serial #, software version and enabled feature code. This is simple to help you keep track of what you have done.
Ok, now I found the right place for this question. For those of us who use Macintosh... will this USB download feature also include software and/or drivers for OSX, now or in the near future?
#38
I will ask him the name of the program on my next work day
#40
thanks for your response
#41
I think we have devised a way to do it but, it will require the puchase of the new harness to make it work.
When/If we get the details worked out 100% rock solid I will be sure to let you know. We have not forgotten but, we have a lot of bridges to get over right now and as soon as we get over that one I will let you know.
Quad
Quad
#42
Quad
Quad
stock03
04-22-2011 09:52 PM
usmcduncan001
09-14-2007 04:10 AM
