Would you let me Sand and Hone your block?
Old 09-19-2006, 10:25 AM
  #31
berettaman's Avatar
sanding and polishing block deck
[QUOTE=abc4yew;1132476]Man, I am certifiabley nuts. I 400 grit sanded my engine block deck this weekend....the result...polished to a shine...no more low spots and casting marks...
I have to admit that I dont know a whole lot about the block and head on these diesels but wouldnt polishing the deck make it easier for a gasket to squirt out under high boost pressure? I have messed with various gas engines in the past and was always told that you need a rougher texture to the decks to insure a positive grip on the gasket. Does this not matter on these engines?
Just curious.
David
Old 09-19-2006, 03:58 PM
  #32
abc4yew's Avatar
Berettaman, Geeze, I hope 5 layers of shiny steel in the gasket don't squirt out from between those 26 studs. If this gasket was rubber or cork maybe but on a molecular layer 400 grit leaves lots of grip on the smooth steel gasket. But I guess we'll find out. ks
Hintz
25
06-01-2008 07:59 PM
wana12v
15
07-29-2006 12:10 PM
Hoss
12-10-2005 02:30 AM
mhuppertz
10-28-2004 10:16 PM
Quick Reply: Would you let me Sand and Hone your block?
