would a CP3 mod help?
I got an 05 6spd with a TST r49,GDP big line kit, FASS 150gph,F1 flux 2s and soon to be put on phat shaft 64/14 turbo and i was wondering if i should get my CP3 modded and if so which stage mod should i have done. Also what does everybody think i should stack my TST with?
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
I would try the DIY CP3 mod first. Cheap and easy from what I hear. I have a friend that has the smarty stacked with the tst and loves it.
i think with the amount of fuel you are able to produce with your current setup, that a stage 2 cp3 would best fit your application. i have a simular setup with the diy mods done and still drain the rail instantly. and by that i mean cruising down the highway if i stab the throttle or even just roll onto it i can pull the rail below 14,000 psi by the time my foot hits the floor. and it doesnt rebound until i let off. just my .002
Jethro6213
19
07-11-2008 11:59 AM
SlowSixSpeed
11-22-2007 04:15 PM
BADBOWTIE
28
07-14-2007 02:36 PM
megacabrule
33
05-10-2007 01:07 PM
