which wire to tap for gauge power?
I am installing the combo boost and pyro gauge and was wondering which wire did you tap into for keyed power? Thanks, Wade
There is one screw right above the trashbag hook that needs to be removed 6or7mm I forget. After that the dash bezel will snap out giving you access to the cig lighter wire.
I installed the Westach Combo Gauge and tapped into the dimmer switch. If you use the lighter, your light will be on day and night and will not be able to dim it. The wire to use is a orange with a black stripe. There are 2 of them and I think it is the bottom one. You can check it out with a voltmeter. Good luck.
Guys, which wire on the back of the cig lighter is the hot one? There is a red one with a stripe and a black wire witha green stripe. I initally tried tapping into the red wire and got nothing from the gauge. Now I tapped into my trailer brake 12v supply, and I get a weird reading on the gauge - it settles to 5psi at idle or when the truck is off.. I can't figure out why it won't go to 0. The ground is solid, on bare metal. I can't figure out if it's my power source that's giving me trouble or I have a bad gauge.
I'm currently tapped into the trailer brake controller 12v line. Does anyone think this is too much power for the gauge a problem otherwise using this wire? I don't have a test light and unfortunately I'm not very experienced in electrical stuff. Any thoughts appreciated!
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
fade94
09-16-2008 11:50 AM
TPilaske
16
11-22-2002 08:15 PM
