Winch on a 3500 CTD
Winch on a 3500 CTD
Quick question here- I want to get a winch for my truck, and I am looking at the Warn 16.5ti for my '05 3500 4x4 CTD Ram, but I was not really wanting a new bumper right now- in the future yes, but not right now. How can I attach the winch in the same manner as the power wagon? Is there ample space anywhere for the same install, or will I need an external plate mount to hook it on the frame? Just pondering ideas here, I appreciate any help.
Rattler
Rattler
Rattler, I have a Warn 12500 mounted on a Road Armor winch bumper. The winch fits perfect and looks pretty clean. The mounting set up is basic, and seems to be strong enough for my use.
The only issue is the clearance between the winch and a/c condensor, Right now with the stock intercooler its OK like 1/8", thats with the bumper out as far as the brackets allow. However since I'm putting a BD cooler in and it is 5/8" wider, I made up some spacers to extend the bumper out. It still looks good, just exposes more below the grill.
I have pictures in my profile
onetun
onetun
I think the clearance issues was one of the reasons there is no factory cummins power wagon. If I had the dough Id get a front receiver mount and bolt the winch to a receiver plate. Then Id be able to winch from front or back, and lock it safely away when not in use!
Look at Warn or do search. Warn makes a 2" reciever you can mount to the frame, and then you can mount your winch to a plate or piece of c channel as I did. You can then install to either your front or back receiver. The winch (12500) and plate weigh about 130 lbs.
Alright, sounds as though I need an alternate route for this then. Should I be able to use one of the mounting plates and get it in, or are the intercooler and trans cooler going to interfere with that? It is looking like I am going to have to get a replacement bumper for this to work.
I'm with Jrussell, when I was inquiring about the reciever mount winch, they wouldn't advise over a 10k winch. I would go for a solid mount even though it is more of a pain. Better safe, then watch your winch try to run away from your truck!
Rattler
Rattler
I'm intalling my new bumper and winch this weekend. I took the stock bumper off already. Trust me, there isn't enough room behind the stock bumper for a winch. The only reason it fits back there on a Power Wagon is the PW runs a hemi. No intercooler. Sorry
Hidden Hitch, Curt, Reese etc. Some say “no drilling necessary”, some don’t…. http://www.etrailer.com/products.asp...=Dodge&t1=&h=e http://www.trimascorp.com/towing.htm
If the truck is so front heavy (Cummins over 1K#), what would the benefit be installing a heavy duty bumper that can carry a 16.5K Warn winch, if the total weight (bumper 210# winch 130#) is going to sink the truck nose in.
As mentioned on the above posts...for the mighty heavy Cummins (again IMO), if stuck, the solution is to install a front hitch receiver that can support a 12K to 15K cradle winch.
This receiver will have to be strong enough to carry the front up and use it in the back receiver if needed.
FYI, this bumper concept is being built as I am writing, if interested, stay tuned for information and photos when they become available.
