Wilson thrasher and GDP 2 micron is it possible
Does anyone know if the wilson manifold will work with the GDP 2 micron kit? I also have a oil bypass wondering if this would cause a problem as well.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
why would you have problems with the bypass? mounting it? mount it somewheres else
welcome to the world of bombing. 1 piece is a bolt on and everything else is cut and fab.
here is the link of the oil bypass im using.. Clearance might be and issue?
http://www.nucmotorsports.com/pdf/Do...structions.pdf
I beleive NUC uses amsoil filters, so why not get the amsoil kit and mount it out of the engine bay, where you also get an oil cooling effect. Also consider amsoil says not to mount the bypass on the motor.
Glacier has 3 different mounting options now. You've got the standard one that goes under the intake which would be used with the stock intake as well as the Glacier intake.
They also have a cylinder head mount that puts the filter setup just in front of the intake.
There is also a remote mount that puts it down on the frame. You have to use this one if your truck has an APPS.
AH64ID
66
12-20-2012 08:09 AM
CutlassRacer
14
05-05-2010 10:44 PM
Killdmycobra
10-15-2009 11:47 AM
jetski428
02-27-2009 05:39 PM
Roperteacher
04-28-2008 11:09 PM
