Will they fit on a dually?
Buddy of mine ordered a new set of bfg mt's and is going to have them installed tomorrow. They are 285/70/17 and are going on the stock wheels. Btw it is an 03 quadcab 4wd. Thanks
Well I was just curious, I will post tomorrow and let you know how it works(or doesn't work) out. My personal thought was that it would look pretty darn sharp. We shall see?
They will look good but I think they are going to rub on the rear.Post some pics of the gap when they are on, there are alot of people curious about this tire for there dually's.
If there touching you will be building heat in the sidewall and risk a blow out.I personally would be concerned especially towing.Every brand tire measures a little different even though they state a certain size.I have cooper 265/70/17's and they are wider than my friends bfg's of the same size,so the gap will vary.This pic is of mine with a 1/4" spacer.
Thanks Blu. That looks awesome! Makes me wish I had a drw. It appears that you have a leveling kit in the front? And did you add a spacer to the rear? Regardless looks great! My friends truck is white with all chrome acc. I think that it is going to look good as well.
Thanks O4, i did put a 2" leveling kit on front, and i put 1/2" spacer on the rear my lugs are just a little below the top of my lug nuts though put seem like they are holding really well!
I'm running 2 1/4" spacers(1/2" total per side) for the 265/70/17 firestone destination m/t's. Had about 6500 lbs on the rear axle tires didnt rub at all, tires were all at 65psi
Running stock studs with a 1/4" spacer. With a 1/2" the studs are not long enough to come past the top of the lug nut.I know these wheels are hubcentric and all the load is on the hubs but the lugnut stiil showing threads is a concern for me.
