will 03' stock clutch handle "hot" juice???
Old 09-19-2006 | 11:05 AM
CTDowerTN's Avatar
my 03' has 65K on it, and iam wanting to add the "Hot" juice here soon, iam adding a pump at the same time too, which i probally should anyways right?? well, will my clutch hold up to it u think, as long as i dont dog it alot?
Old 09-19-2006 | 11:17 AM
Sloverado's Avatar
I didn't think they made a HOt juice for the 03-04 trucks. If so my stock 05 clutch held it but I only had 125 miles on the truck when I put it on. If you have slipped it much or burnt it so it is glazed my guess it won't hold.
Old 09-19-2006 | 11:19 AM
CTDowerTN's Avatar
yeah, they make it for the 03-04 trucks, u just have to send it to edge for them to put it in... there's no code to punch in... it takes about 2 weeks for them to do it, and $100...
BTW, how did ur MPG do on urs with it? and does it smoke alot when its turned up?
Old 09-19-2006 | 11:30 AM
Pooter's Avatar
One way to find out, and even if it does slip, turn it down a tad until you have some money for a clutch...
Old 09-19-2006 | 11:49 AM
Sloverado's Avatar
My mpg were about the same. When in higher levels it went down do to the lead foot lol. I would send it in for it and have it for when you want it then. I remember now that they did offer it. I t is like the juice/ez stack. IT adds a little pressure too. I had a brain fart sorry about that.
Old 09-19-2006 | 04:20 PM
BigDan's Avatar
Just for reference I never slipped my clutch not even once. Then I downloaded the Smarty 130hp program and boy did it slip. It was almost smoking after using it for 1 minute. So most likely the HOT will smoke your clutch. Save that $100 twards a clutch upgrade. Because what good is extra power if it slips your clutch every time you get on it.
P.S I only have 50K on my 03
Old 09-19-2006 | 08:32 PM
CG98x's Avatar
My Hot juice did not slip my stock clutch. The power does not come on until things are spooled and it has a certain rpm and then it flies. I couldn't slip mine until I stacked the Diablo then that extra fueling down low made the clutch start having troubles.
Mechanos
13
11-01-2016 04:27 PM
Silver Ram
07-09-2010 11:12 AM
edwinsmith
04-14-2006 03:53 PM
Dodgecum 04
12-07-2005 01:08 AM
duallydave
08-07-2005 09:38 PM
Quick Reply: will 03' stock clutch handle "hot" juice???
