Why cant things just be simple - water inj
Ok guys-got a simple question...what size should the hole be for the ports for the 375 ml nozle into the head. After reading and studying and worrying Ive finally made my mind up to go with Snow and I have been calling them for 3 days to find out what size hole to port into the head for their 375 ml nozzle. Secretary and then tech voicemail....then secretary voicemail - overand over and over and flipping over - noone will call back.
I have the head ready at machine shop for porting and this is all Im waiting on
All of the nozzles use 1/8" npt.
Looking at the installation instruction Snow Install instructions you will see they tell you to tap for 1/8" NPT.
Administrator/Jarhead
Dang it, Dan... you're tapping the head with water? Shoot, go with NO2! .
On the intake horn, a 1/8 NPT will work it. I got one of the cheap ones from GDP that already had the holes tapped, and flowed better than the stock one. Be a little more specific if I'm on the wrong track, I could assume that you have some head work done from your post... ?
Dan:
Mark only knows how to spray NOS from a 10lb bottle directly into his intake,....NOT how to spell it!!
Sorry Mark,......couldn't resist that.........
madhat
02-09-2009 07:26 PM
9 sec camaro
20
08-26-2006 01:30 PM
