who is making the most HP with any 62/1x turbo???
#33
Originally Posted by SmokinDodge12V
Twest I see in your signature of your 03 that you have a Triple Dog with the Crazy Larry program but I thought CL was not available for 03s.
#36
1 Post
Originally Posted by twest
The latest version Has the CL for 2003.....
#37
Originally Posted by AK RAM
Geez dude. Do you have no shame? Is that what you tell your customers?….right after you sell them a 62mm turbo that keeps 552hp below 1300*F?
#39
It turned out to be a EGT war more than anything. I think it has way to much to do with trucks, alttitude, weight, towing, so much that EGT's are way off. I did get my info, as I'll problably go with the 62/12, as it's still bigger than my stocker and should do fine with the range I want to run. Now off to find that money tree
#40
for what its worth the 62/14 will make 525 hp but it will be in the 1500 range. towing (7,000-10,000) in the 450-480 range should get you livable egt's, I am thinking 1280 or so. the 64/14 is cooler but have more surge complaints than a 66 .
#41
Just got back from a camping trip. Trailer weighs about 9000 LBS. With the Quad box on the 65 HP setting and the II 62/14 turbo my cruising egt's were between 900-1000 deg. Uphill runs netted about 1100 deg. This is at about 70 MPH and 6 people in the truck.
With the stock turbo and same setup crusing egt's were 800-900. All pre-turbo
stock600
Competition / Pulls / OffRoad
03-11-2008 01:13 AM
roberts11260
02-09-2007 05:35 AM
sled4fun
09-08-2006 05:54 PM
