Who here has used Willys Whistler?
Who here has used ****** Whistler?
I like my whistler it sure sounds good. I have the original i havent made that cold air mod yet. who else here uses ****** whistler and do u like it? I noticed awsome sound but I wonder if I maybe need a AFE stage 2 to lower my egts?
no air filter will solve your EGT problems...for some reason your truck just seems to run hot.....ditch your edge and get a smarty....smarty seems to run WAY cooler then the box/modules.....or buy a turbo.
I love Mark's ****** whistler he started my performance madness.....LET HER BREATH
mind you I ventured from the original design & used a universal mount AFE
How many people have told you how to fix your your problems? I swear I have seen just about every respected person on here try and help, but you just dont listen.
I think you need to sell the Cummins and buy a Powerstroke.
What he said ^^^^^. You've been having problems with your truck and the Edge for a long time. If your that concearned with your EGT's pull the juice
read my reply. i said i GAINED MPG with the whistler. My truck problem is fixed. 14 other people told me they run the same egts as me even higher. because my truck is a 2004.5 and has a 3rd injection event to make higher F to burn out cat. Please respect people here.
AAll i meant was if someone tried the whistler versus the afe stage 2 and what did they notice?
1500 F is HOT for a 3rd gen. A intake will not help you EGTs enough to make a difference. The only true effective way to reduce them is to get a new turbo or eliminate the Edge.
PS- I have a Edge J/A and I've never seen above 1500 even while towing in the Mountains of CO. I also have pillar gauges to cross reference the Edge.
I love my whistler. I replaced the amsoil with AFE Pro Guard and just ordered the short radious 90 to turn it into the fender and then build a box to make it cold air
sallyman1
01-26-2008 12:57 PM
sallyman1
01-25-2008 06:11 AM
jasonstacked06
15
12-11-2007 11:37 AM
proworks1
07-11-2007 11:58 AM
DodgeDemon
06-27-2007 10:14 AM
