who built there own drop track bar mount?
i was lookin on here a while back and someone has built there own track bar drop bracket and sway bar drop bracket. i have been looking for it and cant find it! if any one who has done it or has pictures please share or if you know what the link is that will help. thanks in advance.
The sway bar is easy enough to do. You just need to lower it with a 2"-3" (depending on your level kit) block shaped and drilled to match the factory mount. But, I recommend you use longer, stronger links instead. The factory end-links are pencil thin and prone to bending.
Can't help you on the track bar drop bracket. With that little bit of lift I'd use a longer track bar instead. I know it will cost you a bunch more, but with the better connections at the end it well worth it.
I bought mine from Don Thuren at (805) 886-9250. Give him a call and he'll set you up.
dweller
07-11-2013 10:32 PM
CTD2001
08-22-2009 10:03 PM
Ron R
09-16-2008 11:09 AM
