White Smoke-Blown Head Gasket I think?
Old 09-27-2006, 09:24 AM
Patriot2500's Avatar
Truck starts fine, no power loss, runs fine, everything normal.
Old 09-27-2006, 09:31 AM
Pooter's Avatar
And only does it with the box on it?
Or just started doing it reccently when you took the box off?
Old 09-27-2006, 09:42 AM
The box has been off the truck since May. I just noticed the change yesterday afternoon. I only run the BullyDog now on level 2 (90hp).
Old 09-27-2006, 09:55 AM
Pooter's Avatar
Best bet may be to just have the dealership take a peek without the box, cycle it before you take it in, and just see what they say.
Weird thing is, it still running fine, starting fine, etc
Unless maybe just one injector? And you dont really notice?
Not sure, just trying to help you trouble shoot...
Old 09-27-2006, 10:01 AM
I called the dealer and he suggested that the computer needs to be reflashed. Also called a mechanic friend of mine and he suggested I put everything back to stock and see if it still does it. I really don't want to spend $85 an hour at the dealer if I don't have to.
Old 09-27-2006, 10:02 AM
I do appreciate your help. When I get home from work this afternoon, I will check the oil for diesel and post up. That will definetly tell if one of the injectors is bad.
Old 09-27-2006, 10:23 AM
I just went out and put the truck back to stock settings. If one of my injectors is bad, should I just upgrade to a set of aftermarket sticks or put some OEM replacements in?
Old 09-27-2006, 10:25 AM
Pooter's Avatar
No problem, let us know how it works out.
As for the injectors, if it is them, maybe swap them out for some aftermarkets, but im pretty sure they want a full set of working injectors to avoid the core charge, but dont quote me on that.
Truck isnt under warranty any longer?
Old 09-27-2006, 10:26 AM
It is under warranty but they will see that I had a chip on there and then the warranty is voided.
Old 09-27-2006, 02:59 PM
abc4yew's Avatar
"Aftermarkets" are just modified or new modified nozzles on: your injector bodies, remanufactured bodies, or crappy bodies. The only way to get a better injector than you have is to buy a new one from a Robert Bosch dealer or distributor or directly from Cummins or Dodge. If you don't ask you will get remans. I got remans for $150 a piece from Ind. Inj. but 2 were from 1999. or maybe they were better in the beginning like a lot of things... ks
Old 09-27-2006, 03:40 PM
Well drove home today and saw no smoke at all. Truck ran great, no problems at all. Maybe the software on my PowerPup needs to be updated?
Old 09-27-2006, 03:50 PM
morkable's Avatar
I live in the land of -40 and I have never seen much in the way of white smoke coming out of my truck. Lots of black,, I have went through 3 winters with my truck so far,, and I rarely plug in, other than when it gets down to -25 or so
Kevin
Old 09-28-2006, 06:27 AM
Update
Stopped by the local diesel shop and explained my problem to the tech. He says the BullyDog is causing the smoke and that I should take it off immediatly. He also said if I blew an injector or did other damage, it would blow so much white smoke that it would look like a ghost was behind the truck. Anyway, drove about 50 miles last night and no white smoke. Checked fluids when I got home and everything was normal.
Here is another question I have regarding the BullyDog. I bought the programmer used in June and haven't updated it or anything yet. Would it be worth it for me to download the newest program off their website?
Thank you to everyone who posted up with their opinions.
Old 09-28-2006, 07:23 AM
OT-OF-Here's Avatar
Injectors
While I'm sure your mechanic is much more proficient than myself I will tell you based on experience,... NOT my opinion that I had most of the white smoke on INITIAL startup and much less if any after that. Also if the truck sat over the weekend it would be a major fog out of white smoke. I had ALL of my injectors doing this and I didn't have a ghost following me down the road. My kids F550 that had bad injectors just smoked on startup also, fyi.
Old 09-28-2006, 09:21 AM
I don't have smoke on startup.
SkinnyBTN
06-26-2010 06:29 AM
1stgenatheart
09-13-2007 07:46 AM
blownsmoke2
19
04-29-2007 10:25 PM
mike herron
02-01-2004 11:19 AM
soopertrooperII
01-12-2004 11:28 PM
Quick Reply: White Smoke-Blown Head Gasket I think?
