Where under dash can I tap into reverse light wire?
Installing some backup lights that have ability to come on when shifted into reverse.
Ideally want to find wire under dash or as close to dash as possible.
TIA
TIA
There is a reverse wire in the trailer wiring harness at the back of the truck. If all you want is the lights to come on when you are in reverse then just tie in to that wire right at the back of the truck. Just another option.
If you have a standard tranny, take into the reverse switch on the passenger side of the tranny. It's the only electrical connection there. Two wires.
Automatic tranny, probably the same thing but harder to find the wires I would imagine.
However they are PIAA's and he told me the switch has three settings.
1. lights on
2. lights off
3. lights on when in reverse
I would imagine this is why he asked me to find out where we can tap in near the dash, based on the 3 different switch settings?
P.S. I have an auto
I used the wire that feeds the 7pin trailer connector. Just unbolt it from the bumper and pull it out a bit. the you can use a wire tap and some elec tape and your done. You will need to run wires to the rear bumper anyways so its not much more work.
I just put on halogen b/u lights. The purple/black wire is the b/u lights and I used the white/red (12v+ to the trailer batteries) to power them thru the relay. I got 2.5v drop just using the pur/bk to power the lights without the relay. I wish I would have had wiring diagrams - there's extra relay spots in the relay/fuse panel. Craig
Yes, I'd think you'd be best off putting a relay in rather than getting all the juice for the additional tail lights from the 1 factory wire.
Have not put new ones on my Dodge but had them on my old Ford, they were too dim until I ran a seperate bigger wire back to the relay from the battery and just used the factory wite to trigger the relay.
(if you know what I mean...)
I just tapped into what I believe is the correct wire, under the dash on my 06 mega, it's white/bright green...waaaay up under the dash, I did it for my rear view camera switch...I'll let you know how this turns out...
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
NJMurvin
01-14-2010 07:59 PM
APD
03-07-2005 06:48 PM
